Accenta G3
Guest SteveT
I have recently moved to a house which came complete with an Accenta G3 system and PIR detectors. Of the two part set programs, one is already programmed to allow use of the upstairs rooms and the other is unused. I want use the free programme to allow use of another area. The operating instructions describe how to part set the system once programmed but not how to create the programme in the first place. No information on ADE web site either. Any advice gratefully received.
Setting up the part set suites is an engineering function. You require the services of 1no. intruder alarm engineer. :)
There is a listing here if you don't have an installer.
Thanks - looks like I'll have to call in the professionals
:lol: I hope you wrote that for Lurch's sake
Zak Tankel - Managing Director - Security First (UK) - www.securityfirst.uk.com
Disclaimer: Any comments or opinions expressed by me are my own as a member of the public and not of my employer or Company.
Guest Cerberus NI
Been a while since I seen Bodie and Doyle in the RS2000 right enough - hurrah for the professionals indeed! :ninja::ninja:
Like this?
If you've got Freeview they're on Channel 38 (Men and Motors) most days! B)
It's Minder at the moment :P
Channel 35 now. ;) If you're box still says 38 it needs an OTA update.
