toenee Posted December 20, 2005 Posted December 20, 2005 HI All, Introductions first I'm a engineer that has been in the trade for about 15 years the company I work for used to be in the tv repair and sales business but with the advent of the throw away product we diversified into burglar cctv access and have just started into fire systems. We also keep are hand in design and installation of aerial systems As for a topic what do people think about the big Lunar ceiling pir/microwave we have just got one with its dedicated key pad to play with. We hoped to use them in opposite corners of a large room with tall ceilings to avoid the plaster cornice and ornate walls. One problem we may encounter is that these detectors have anti mask. We will do some tests in our work shop then if possible post the results if any body however has used these detectors any advice as always would be welcome
Guest Posted December 20, 2005 Posted December 20, 2005 toenee said: HI All, Introductions first I'm a engineer that has been in the trade for about 15 years the company I work for used to be in the tv repair and sales business but with the advent of the throw away product we diversified into burglar cctv access and have just started into fire systems. We also keep are hand in design and installation of aerial systems As for a topic what do people think about the big Lunar ceiling pir/microwave we have just got one with its dedicated key pad to play with. We hoped to use them in opposite corners of a large room with tall ceilings to avoid the plaster cornice and ornate walls. One problem we may encounter is that these detectors have anti mask. We will do some tests in our work shop then if possible post the results if any body however has used these detectors any advice as always would be welcome when you say corner...
Guest Posted December 20, 2005 Posted December 20, 2005 never liked 360's....might work in the corner tho..as 180's..
Guest Posted December 20, 2005 Posted December 20, 2005 toenee said: with tall ceilings to wharehouse tall?
Guest Posted December 20, 2005 Posted December 20, 2005 Mr Happy said: wharehouse tall? warehouse tall....most of the time yes..
Guest Posted December 21, 2005 Posted December 21, 2005 toenee said: We hoped to use them in opposite corners of a large room with tall ceilings to avoid the plaster cornice and ornate walls. Personally, I think it's a ridiculous idea. There's always a way to get a cable to a point tidily. toenee said: One problem we may encounter is that these detectors have anti mask. How will that cause a problem? If you don't need ant-mask, don't use it. If you do need it, then you're running before you can walk.
