Covert Cameras
Guest priory1994
http://www.iviewcameras.co.uk/MemocamCCTVSystemsdeals.htm
Thats one of two I have come across, I was sent some info on a similar camera which I was thinking of fitting into smoke detector housings, I will try and find the info for you.
  • 3 weeks later...
Not a big fan of pin hole cameras fitted in boxes, I always find it very hard to get the right view. They are ok if fitted at head height but anything above that and you will need to angle the box down a lot.
You could mount a small camera inside a halogen fitting or get a bullet camera and fit it under your sofit, fairly hard to see. The bullets tend to have audio on aswell.
Top tip: if you ever catch fire, try to avoid seeing yourself in the mirror, because i bet thats what REALLY throws you into a panic and dont forget the one thing you cant recycle is wasted time.
