To Solder Or Not
Guest heliart
Guest graale00
Can't say I've ever tinned the ends, I always twist the cables tightly together and snip the top off, seems to do the trick.........so far!!!
There's a bit in 50131-7 about joints and soldering.. :sofa1:
I still encase the joints in a JB, but don't use the mechanicals of them.
I never solder / tin panel connections in case modifications need to be done at some point in the future.
Joints, for example in a pir to add extra ccts are either soldered or crimped with 99a crimps. :yes:
Regards
Bellman
Is that the RS ones?
Any more info on them, i have used some in the past for pre-wired contacts.
PG Security Systems
Somerset
SSAIB Certificate of Merit Installers.
www.pgsecurity.co.uk
Regards
Bellman
solder only here..crimps =high res....tho at 2am its twist and tape..(only kidding)honest.. :ninja:
Crimps for the 2am jobs :)
Anyway, they are the gel filled blue ones BT use in the green roadside cabinets.
never found better crimp terminals. :yes:
Mate used to work for BT and still has boxes of em. :whistle:
Regards
Bellman
Chris is there any one you dont know who can supply the odd bit of gear now and then.
Dave Oxendale
York based security systems engineer.
What i usually do if i need to carry on to another detector, is break In the the cable by just leaving a loop in the first detector and then breaking the sleaving cutting the ones you want leaving the ones to carry through, but if its an addon, i would be able to do this, i always solder and either heat shrink (If i have any) or tape up.
Dean
WTF :no:
Jef
Customers!
WTF :no:
Jef
So you have never done this.... ie when you supply a PVC window with 1 cable and hide inside the plastic window, so you dont see the wires, and you have a contact and a siesmic, you let the wires carry through to the Contact or vice versa, that way they DONT have to be joined.
Nothing wrong with that Jef, so why the :no: face
Watchdog Security (Manchester)
I agree with you Watchdog, Maybe Jef got the wrong end of the stick, or never back to backs 2 pirs on 1 cable!
Bellman
that will be the same green cabinets that sends a thousand alarm systems into line fault every time in rains... :hmm:
Bellman
its me your talking to... :whistle: when was the last time you were out at 2am 'mr leave it for the dayshift' :ninja::P
