Guest Endplate Posted December 22, 2005 Posted December 22, 2005 Hi everyone, I got 2 questions to ask 1. Recently the back up battery died in my house alarm system since the battery was replaced whenever attempting to set the alarm error code no.99 appears on the keypad display. Doeas anyone know how to solve this error 2. My girlfriends house has the same alarm system fitted but I am unable to change the alarm code. I was advised to look behind some of the panels for a number by the alarm company but there was no number. Do you have any advice?
morph Posted December 22, 2005 Posted December 22, 2005 Best advice get in contact the original installer or get a local engineer in to look at both.
PJF Posted December 22, 2005 Posted December 22, 2005 Not totally sure what error 99 is(poss software) but why not give Aritech technical a ring on and they may point you in the right direction. Your panel may have engineer reset on tamper!. Top tip: if you ever catch fire, try to avoid seeing yourself in the mirror, because i bet thats what REALLY throws you into a panic and dont forget the one thing you cant recycle is wasted time.
Guest Posted December 22, 2005 Posted December 22, 2005 Hi everyone,I got 2 questions to ask 1. Recently the back up battery died in my house alarm system since the battery was replaced whenever attempting to set the alarm error code no.99 appears on the keypad display. Doeas anyone know how to solve this error 2. My girlfriends house has the same alarm system fitted but I am unable to change the alarm code. I was advised to look behind some of the panels for a number by the alarm company but there was no number. Do you have any advice? sounds like the remote reset code...never liked that long winded remote reset procedure..
PJF Posted December 22, 2005 Posted December 22, 2005 No mate, "call alarm Co code 99". For a remote reset. Top tip: if you ever catch fire, try to avoid seeing yourself in the mirror, because i bet thats what REALLY throws you into a panic and dont forget the one thing you cant recycle is wasted time.
Guest Posted December 22, 2005 Posted December 22, 2005 No mate,"call alarm Co code 99". For a remote reset. that could be an error to some people.....im going for remote reset code......
