Guest Kev Posted December 22, 2005 Posted December 22, 2005 Hello, I am wondering what size and type of battery to get for my alarm system. The outlet i use has all sizes.. My alarm consists of: GALAXY 8Plus Control Panel Internal Sounder External SAB 3 PIR's (maybe 4 soon) 1 Panic button (Obviously doesnt use power) 1 Keypad 2 door contacts (Obviously doesnt use power) Thats about it. Thanks to anyone in advance, this is my own system and i have been using a 7Ah, but im was thinking that it most likely doesnt need it. Kev
whistle Posted December 22, 2005 Posted December 22, 2005 who makes these up... Agreed Well i only have 3 pir so i will take out the 7amp and fit a 2.1amp ?????
Guest Guest Posted December 22, 2005 Posted December 22, 2005 lol i do 8-) OK well thanks guys. I will just stick with it then I just wondered if any of the smaller sixes would suit it too.
Guest Guest Posted December 22, 2005 Posted December 22, 2005 Would i be right in saying that since the onboard fuses are 1amp.. the max draw is 1amp? Therefore.. according to the link posted by RJB.. (thanks) then a 4.2 amp battery would keep the system on for around 4 hours? 10 AMPS x 3 HRS = 30 Ah and the chosen option being 38Ah Kev
antinode Posted December 22, 2005 Posted December 22, 2005 Would i be right in saying that since the onboard fuses are 1amp.. the max draw is 1amp? Therefore.. according to the link posted by RJB.. (thanks) then a 4.2 amp battery would keep the system on for around 4 hours?Kev It does'nt work like that mate. It all depends on the current draw of the system and the actual capacity of the battery (usually depreciates over time, but I've seen 7ah batteries putting out 9ah!) Amp/hour literally means 1 amp per hour, so a 7 ah batt can supply 1 amp for 7 hours, 500 milliamps for 14 hours etc. The system should be able to support itself for a minimum of 12 hours when running under battery power only. Trade Member
Guest Guest Posted December 23, 2005 Posted December 23, 2005 OK mate.. Thanks for your replies.. and i will buy a 7Ah tomorrow. Thanks Regards, Kev
Guest Guest Posted December 23, 2005 Posted December 23, 2005 i have only worked on three galaxy panels, and all three have had 7ah batteries in, if thats any help
jb-eye Posted December 23, 2005 Posted December 23, 2005 The system should be able to support itself for a minimum of 12 hours when running under battery power only.Antinode, the above statement is not entirely correct is it. Jef Customers!
