Were To Buy
Guest Guest
please can anyone tell me were i can buy cheap pir bell boxs panals and so on
Several online retailers can supply you with suitable equipment, have a quick google for it.
Regards
Bellman
You'd be better off learning the (a) trade before buying equipment.
Guest Cyberprog
TLC Direct do a nice range of ADE panels and bell boxes, easy to use and setup. Not bad pricing either I don't think :) If you're after something a bit more sophisticated then I have some other links, but as I've not done a lot with that sort of systems I'm not sure if i'm getting the best pricing for them :)
Please dont recommend optima's, accenta's or logic 6's
Adi
Guest Cyberprog
Adi
Any particular reason? I've seen lots of them in my local area, and the ones that i've installed have always been very solidly built, and the menu/programming is pretty nice. Ok they've not got a nice LCD display, but the display they have is pretty intuitive. Hell i've got a Logic 4 in my house ATM, got to be 10 years old at least, never had any problems with it! Only getting upgraded as a chance for me to test out the galaxy panels i've got recently :)
Talk about low end. Some on here slag off the veritas but ade stuff is a damn sight worse. Programming is bit basic a slight problem with mains or batt and they lock up and if your fitted them for a living where is time and date stamped log, some old biddy could go out not set her alarm get done over and blame you for the alarm not going off.
For just a few quid more you could you double the quality of your panel and installation by fitting a 9651 or a few quid more fit an excel or other.
so were is the best place to get a excel from
There is an online shop alert electrical or maybe a local outlet.
