Correctly Wiring Menvier Sd1+ To Accenta 8
Guest pwalker2323
Guest pwalker2323
I am keen not to mis wire this and wanted to ask a hands on expert for advice. Only one trigger ie alarm ie no fire.
Please could someone advise of the correct pins to come out of the Accenta with, which input to feed on the Menvier and whether the 1k resistor is required.
I am not sure about this trigger polarity slider, whther to use the dialler output on the accenta (if it has one?) or whther to use the bell output and then will i need the resistor?
any straight Ive done this install before and heres the abc would be appreciated
regards
This is a public site, so without giving to much engineering info out.
You have just about got it licked by yourself.
1.Trigger correct.
2.No resistor.
3.No dialler connections, use the bell output and still no resistor.
Have fun :)
Top tip: if you ever catch fire, try to avoid seeing yourself in the mirror, because i bet thats what REALLY throws you into a panic and dont forget the one thing you cant recycle is wasted time.
I thought the Accenta had the outputs for a dialler?
Easy way to tell, they're either there or they're not, on the top of the PCB. If they are connect to the INT outpt, if they're not the use the bell output as above.
