Guest spyro2310 Posted January 1, 2006 Posted January 1, 2006 Like all the other poor souls out there I have also moved into a new house - luckily i do have the access code but no idea how to program the zones. can anyone help? Thanks
morph Posted January 1, 2006 Posted January 1, 2006 These forums can only help you with a user manual as we do not give out engineer manuals.
Guest ALSEC Posted January 1, 2006 Posted January 1, 2006 If I remember rightly the user guide and installer guide are all the same manual?
morph Posted January 1, 2006 Posted January 1, 2006 If I remember rightly the user guide and installer guide are all the same manual? They are. A few of us have pdf's of only the user parts(think they are also in engineer manual section) We also have company specific user instructions.
FASTCAR Posted January 1, 2006 Posted January 1, 2006 Hi, The zones are pretty much fixed on the xm , only thing you can program are the timers.
Guest spyro2310 Posted January 1, 2006 Posted January 1, 2006 Any PDFS would be great I have no instructions at all Thanks
Guest spyro2310 Posted January 2, 2006 Posted January 2, 2006 To change code:Prog then old code the 8 then new code press reset reset reset done. To set: enter code and leave. To unset: enter code. To set with zone omitted: enter code press omit followed by the zone number you require to omit followed by set. There you go thats about the full extent of the user guide. Pete Peter thanks for your help. regards
