Hi From Kent - Cctv Advice
Guest matopia
HI Mike,
The first IR camera you suggested from RFconcepts is very good and I have used it in many situations. I havnt had the time to read through all the thread so please excuse my bluntness.
Regards.
Mark
secure4.me.uk digital cctv
Guest matopia
HI Mike,
Ok! excellent. Do you mean this camera
Can you give me examples of the situations you have used it in? What sort of true range does it have at night (with enough light), and what type of light (I mean, can you give examples of the light source being used in conjunction with this camera (Colour Sony IR x 49ea-CC70CSHRX-4IR).
Would I need to house this camera or is that the housing as in the picture. My other concern is the camera being destroyed.
I am still undecided on which camera to get, but my choices are slowly being limited to something like this camera or the Samsung 520P or a dome camera or both. :)
cheers,
Mike
That Armour Dome looks simillar to this one..
eBay Again
Image Device:1/3" Sony CCD
◎Scanning System:
○NTSC:525 Lines.60 Field/Sec
○PAL: 625 Lines 50 Field/Sec
○EIA: 525 Lines 60 Field/Sec
○CCIR: 625 Lines,50 Field/Sec
◎Horizontal Resolution:480TVL
◎White Balance:Auto
◎Video Output:1Vp-p 75ohm, Negative
◎Gamma Characteristic:0.45
◎Minimum Illumination:0.5lux/0lux
◎Power Consumption:12V
◎Operation Temperature:-10C~+50C
◎Dimension:
They look awfully plasticy, to be Anti vandel..... Is it plastic on cast ? does it say on the spec. I reckon a nice brick would see those off in a few seconds....
These are the ones i have and there solid a rock....
Not sure the retial but i know they can be pricey esp. with Day night cam.
Watchdog Security (Manchester)
Guest matopia
Dean,
Where did you buy yours from? I'm happy to look up the retail price.
Why is finding a camera so hard? :hmm: I thought anti-vandal means just that, that bricks and bottles etc, would just bounce off the dome. I mean for
Nice Video!!!
I use the vantage and wall mount it no problems.
Guest matopia
The Vantage Dome is better than the LJD one (trust me I have used them both) I can do the dvr with cdr but you will need a monitor or a TV with a composite input to program it, (after that you can watch it on your pc).
Come to think of it you could probably burn cd,s with the other one from your pc.
I dont have a price list to hand but a ball park guess either mentioned domes, the ljd dvr with cdr, psu 100m, of cable bnc's, pc software (no network cables) would come in close to
