WatchdogSecurity Posted January 1, 2006 Share Posted January 1, 2006 Anyone know of any 1 2 or 4 relay cards, ie, for using with rio outputs, which are pcb mounted and have wired terminals. Dean Watchdog Security (Manchester) Link to comment Share on other sites More sharing options...
morph Posted January 1, 2006 Share Posted January 1, 2006 TK Consultants. weildmueller also do do them in a din rail with a choice of 1,4,8,16 and 24. Link to comment Share on other sites More sharing options...
Guest Posted January 1, 2006 Share Posted January 1, 2006 GardTec do some 2 relay cards, and there are some 4 module CPC ones I think (handy relay x 4 all on one PCB for use as 1 unit or snap off as reqd). Link to comment Share on other sites More sharing options...
whistle Posted January 1, 2006 Share Posted January 1, 2006 Used to use the DA rb007 relays they came on a strip and you snapped them off as requiered Link to comment Share on other sites More sharing options...
WatchdogSecurity Posted January 1, 2006 Author Share Posted January 1, 2006 chaps Watchdog Security (Manchester) Link to comment Share on other sites More sharing options...
Nova-Security Posted January 1, 2006 Share Posted January 1, 2006 Used to use the DA rb007 relays they came on a strip and you snapped them off as requiered We use these, as by cutting a couple of links you can change them to do what you want. www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name. Link to comment Share on other sites More sharing options...
Selsport69 Posted January 2, 2006 Share Posted January 2, 2006 Castlecaretech do the ones that Initial use. Very good and very reliable.1,2,4way. Kev Link to comment Share on other sites More sharing options...
hastings Posted January 2, 2006 Share Posted January 2, 2006 http://www.maplin.co.uk/Module.aspx?Module...ages&doy=search try these ! Link to comment Share on other sites More sharing options...
Guest Posted January 2, 2006 Share Posted January 2, 2006 try these ! PCB mounting? Are you sure? Link to comment Share on other sites More sharing options...
hastings Posted January 2, 2006 Share Posted January 2, 2006 http://www.ktassemblies.co.uk/auxiliary.html My mistake Lurch, try this one under 'auxilary equipment' then look for ' multi relay card' they also do loads of other security related pcbs and psu's etc. Have used them for years, top class gear and service. Link to comment Share on other sites More sharing options...
