Veritas Alarm - 8 ?
Guest Bignuts121
Guest Bignuts121
Hi - turned the alarm off as normla this am,
Just gone to go out and the alarm code wont work ? Why ?
I have had the alarm from new just over 2 years - Cant get hold of the installer and have no manuals,
I needs help ASAP - dont want to leave the house unarmed !!
regards
Liam
When you say code won't work, how?
No bleeps, no lights on keypad, code entered but inrecognised?
Is there anything on the keypad other than what there normally is? Could be the system is in a state that means it can't be set for some reason?
There is also a manual posted by me in the last hour or so somewhere nearby, quick search and it'll turn up.
i eneter the code as normla pres full and just a beep ! This is not normally how it works,
just been on texe.com for the user guide but this does'nt help, the unset light is permanently green, is this normal ?
Try 4321 FULL?
Tried that - Also tried 5678 and 1234 Full, Part, Reset Etc. all to no avail !
Do you recommend isolating the elecs to house and turning back on ?
Do it if you want, I wouldn't recommend it though.
When you say can't get hold of installer, do you mean gone out of business can't get hold of or just temporarily unavailable?
Service Timer 3 ?
Does it need a service ? Is this expensive ? Do you know any service guys in SY8 area - Ludlow Shropshire ?
My installer has changed numbers - left message but as yet no reply !!
Thanks
p.s. can this be remedied in the meantime of waiting for a service ?
Service Timer 3 ?
Thanks
Sound like it needs an engineer visit either way.
If you can`t get in touch with your installer somebody on here will be able to help i`m sure
Unfortunately not unless you know the engineer code
Trade Full Member
A service is recommended annually ideally. Some installers will set a timer to expire after 12 Months+ to lock the system out to prevent you using it whilst it is potentially deteriorating. Without knowing what your installer did I can't say, also not sure how the Veritas service timer works but I'm sure it should have given you some indication before locking out?
