Mavrick_001 Posted January 4, 2006 Posted January 4, 2006 Listen to Monteey all.... that's all I'm saying, from what I have leartn on here he knows these panels inside out so I'm sure he knows what he's on about.... and no I'm not being funny with anyone! CCTV Intruder Access Control Tony Hughes, Proprietor, TRADE MEMBER
cdosrun Posted January 4, 2006 Posted January 4, 2006 Mavrick_001, you are quite right, Monteey, Breff and Lurch etc. all know far more about the Texecom gear than I do, and I would follow their advice (and will do myself). I only questioned it because the NPN output transistors on the panel that control the bell and strobe are the same as those for the other outputs (BDP949, rated by Texecom at 100ma for the other outputs, although can pulse up to 1A+), and just wondered if the current draw couldn't be that large. The other argument though, is that is probably isn't wise to load a high current consumer like a bell on a network, and to confine it to its dedicated (fused) power source. However, as I have said before, you lot are the professionals, I am only a student, so I would always take your advice above my own with alarms! Andrew Any statement made or information provided in this post are the mere opinions of the author, and no inferrence is to be made as to the quality of information nor should any reliance be placed upon its contents.
cdosrun Posted January 5, 2006 Posted January 5, 2006 ---deleted--- Any statement made or information provided in this post are the mere opinions of the author, and no inferrence is to be made as to the quality of information nor should any reliance be placed upon its contents.
Guest Lorraine Posted January 7, 2006 Posted January 7, 2006 hi all, I just finished installing, I am very happy. only upstiars sensors left to go! I ended up wiring the +ve, 0v, bell and strobe back to the panel and wired the tamper up to my remote expander. Must say thanks for all the help everyone, it is very much appreciated. Lorraine
