Avaya Ip403
BUSTER
Anyone worked on the Avaya ip403 telephone system. Need some advice on programming etc.
Any comments / opinions posted are my opinion only and do not represent those of my employer or Company
Do you have the manuals.
Look here if you dont, might be something you need here:
HERE
Watchdog Security (Manchester)
I haven't, but I know there are a couple of guys over on ITN that have. (Be patient, not an overly active board)!
Got the manuals, done some of the programming but need to forward an incoming isdn call out on an analogue line.
Whats ITN? :-|
Whats ITN? :-|
Click the link and find out. :rolleyes: (Telecom engineers forum basically).
  • 2 weeks later...
Have not got a system to try it at mo but think you have to setup a virtual user with a permanent divert on, then forward the ISDN calls to the virt and hence then allocate the user with a short code to pickup the analogue trunk for any outgoing.
When I have some time I will give you a bit more detail if you need as that was off the top of my head.
Si
ToneTel Telecom
www.tonetel.co.uk
Si
cheers, any info would be appreciated
  • 2 weeks later...
Guest mrrfj00
WHATS THE PROBLEM ?
WHATS THE PROBLEM ?
Your 'caps lock' button is stuck on. Should be a relatively simple fix. :)
  • 2 months later...
Guest Rockford
I'm an Avaya Certified Associate in the IP Office product range... PM me the problem and I'll do what I can to help out...
