Guest Davidh Posted January 7, 2006 Posted January 7, 2006 I have just moved into a house with a VERITAS 8C alarm fitted. All works OK ( as a new member of this forum, many thanks to the contributor who made available the PDF of the manual as I needed one). I am having a lot of mains electrical work done and every time the power is dropped the external alarm is trggered. Is there any way of stopping the alarm during power off? I would appreciate and help. David
FASTCAR Posted January 7, 2006 Posted January 7, 2006 Hi and welcome , it sounds like your battery is not doing its job.Its either flat , the battery fuse has popped , or the charging circuit is u/s. Its most likely to be a poorly maintained 12v 2.1 Ah battery. Regards.
Guest Davidh Posted January 7, 2006 Posted January 7, 2006 Thank you for your fast respense. Will I find the battery inside the control unit? Regards David
FASTCAR Posted January 7, 2006 Posted January 7, 2006 Yes , its inside the control panel (2 screws ) its also a tight fit. Isolate the mains before opening cover. If you are unsure , get a pro to check it out for you. Regards.
Guest Davidh Posted January 7, 2006 Posted January 7, 2006 Yes , its inside the control panel (2 screws ) its also a tight fit.Isolate the mains before opening cover. If you are unsure , get a pro to check it out for you. Regards. Thank you , I appreciate your help Sorry for the delay between replies but I have 1001 tasks in hand having just moved house. Regards David
