Optima Xm 4 Zone
Guest Guest_steve_*
Guest Guest_steve_*
Hi all, excellent site but dont seem to be able to find the info im after.
Basically, i would like to remove a PIR from the system due to room alterations, How do i go about this procedure without causing alarm or tamper mode to be activated? It is Zone 2 if that makes any difference?
Many thanks in advance :)
What control panel have you got, and do you know the Engineer code..?
