Scantronic. Bell Tamper On Start Up!
Guest Hardrhino
Guest Hardrhino
Hello.... Please help a newbie.
I'm sure i have wired it up correctly.... Ran out of time tonight but only other step i can take is to try another cable!
After this where should i look!!!???
Thanks in advance! :)
Forgot!!! Its a 9651...
Guest Peter James
We're alarm engineers none of us are physic or have a crystal ball? If you want help you first have to give us a clue to what you have done.
Pete
And what make/model the bellbox is would help.
Er........
Anyway, what tests have you done so far to prove or disprove this?
Guest Hardrhino
Fair point.... But if you have a crystal ball things would be so much easier! :)
Here's what i have.
Its a Klaxon 42-504283? Bell Unit.
Wired.....
Bell Unit.___________________9651
Tamper Series____No Conn.
Tamper Return____Yellow______TR
Supply -__________Black______0V
Supply +_________Red________12V
Strobe -__________Blue_______OP2
Trigger -_________Green______OP1
Have belled the cable but nothing more.
Hope you guys can help...
Had a van stolen on monday, as i was trying to get in it!!! Had the house keys etc in it.
Have changed locks but want the piece of mind for the family, if you know what i mean!!
Any help greatfully received!
You've wired it wrong.
Link from -ve to the unused tamper.
Guest Hardrhino
Oh Good..
-ve? Unused Tamper?
Are these connecions made in the Bell Box?
The Tamper Series and Supply Negative as above?
I wanna be 100% as i don't want false alarms......
cheers.
-ve? Unused Tamper?
Yep.
Guest Hardrhino
Thanks Lurch..
One final thing....
I now have Zone Faults when i arm it.
I have 2 PIRs on seperate Zones and 2 Mag contacts on seperate Zones.
I know how to change the allocations of Normal or Exit etc for each zone.
So how should i have them set and what do i need to do with the connections in the panel on unused zones?
cheers
