chipembele Posted January 12, 2006 Posted January 12, 2006 Hi, hope you can help. This morning my wife went to set the alarm while I was stood in one of the zones. The alert started sounding (the one that sounds while you are leaving the premises) before she could omit the
morph Posted January 12, 2006 Posted January 12, 2006 Try 5678 instead of your own code. How old is the system, when was it last serviced.
chipembele Posted January 12, 2006 Author Posted January 12, 2006 Try 5678 instead of your own code.How old is the system, when was it last serviced. I'll try that. It just seems strange that the keypad sound has now gone and wont respond to keypresses. Don't know when it was last serviced as it was in when we moved in 18 months ago. It's worked fine up to today which was probably our own fault anyway. Thanks for your reply.
morph Posted January 12, 2006 Posted January 12, 2006 The system has probably never been serviced and may have inadvertantly been defaulted. I would suggest that you get the system serviced by an engineer, post your location on here and one the engineers on these forums should be able to arrange this for you and advise of the cost.
chipembele Posted January 12, 2006 Author Posted January 12, 2006 The system has probably never been serviced and may have inadvertantly been defaulted.I would suggest that you get the system serviced by an engineer, post your location on here and one the engineers on these forums should be able to arrange this for you and advise of the cost. Ok, my location is Batley near Leeds, just off the M62.
