Guest heliart Posted January 12, 2006 Posted January 12, 2006 What's an ATS Path Fault on a Texecom Premier, can't seem to clear it at all!! Any help greatly appreciated. Quote
Guest Posted January 13, 2006 Posted January 13, 2006 Ats is the equipment used to signal remotely, fault will be shown depending on how system programmed you may have done something retarded like have selected that a modem is fitted when it is not Quote
Guest karl@TSS Posted January 13, 2006 Posted January 13, 2006 yeah ive had that ...wired the bt line in and it went..its their way of sayin "line fault" me thinks Quote
breff Posted January 13, 2006 Posted January 13, 2006 Alarm Transmission System Fault. IE Phone line fault. Quote The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
james.wilson Posted April 27, 2016 Posted April 27, 2016 ats fault is different to an atp fault ats fault is bad your system isn't signalling on either Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
WDT Posted April 28, 2016 Posted April 28, 2016 Did you install the panel, If not speak with your alarm company. Have you changed anything I.e unplugged a ethernet cable, change broadband modem, phone line fault, but with out knowing how it signals the alarm, some of this is just guess work, Quote
Apo Posted July 11, 2018 Posted July 11, 2018 On 28/04/2016 at 07:34, WDT said: Did you install the panel, If not speak with your alarm company. Have you changed anything I.e unplugged a ethernet cable, change broadband modem, phone line fault, but with out knowing how it signals the alarm, some of this is just guess work, I got the same problem and it did happen because i changed network provider. I went from BT to Virgin and i am not sure how i can get the alarm to work now with the app and clear this "ats path fault" error. Please help out. Many thanks in advance Quote
sixwheeledbeast Posted July 11, 2018 Posted July 11, 2018 Contact your installer and have your new router set up again. The error is a warning to say its not polling the server. Quote
