Accenta Tamper Problem
Guest greenpup
Guest greenpup
Please could you help me with my Accenta 8 Mini. I had a power cut and the key pad all jammed, so I replaced the battery, powered down and powered back up. All sirens sounded and I turned them off. The problem is that now the key pad has full power but the tamper light is on. The pad is jammed so I can't press reset or enter the code (which I could do after I had repowered).
Thanks.
Hi,
have you made sure that the panel lid tamper switch is closed and you haven't disturbed any of the global tamper wiring?
Andrew
Any statement made or information provided in this post are the mere opinions of the author, and no inferrence is to be made as to the quality of information nor should any reliance be placed upon its contents.
Guest greenpup
Thanks Andrew. Can't believe it was so obvious. I'd took the cover off to change the battery and didn't realise there was a tamper switch on there.
Thanks a lot
