Guest kev1 Posted January 15, 2006 Posted January 15, 2006 Hi, I'm new here, but really hoping you can help. We've recently moved into our house. The alarm system was working fine, (veritas 8) until the decorator sliced through a wire to a sensor yesterday. I have soldered the damaged wires back together and insulated correctly. (auto electrician). Now when I try to set the alarm, it bleeps fast 4 times and then again and again, and I have noticed none of the sensors illuminate even when the system is in the reset mode. I thought it indicated an open curcuit, so omitted zone 4, went down to 3 beeps, etc etc. Does it need resetting or something? I have no manuals for it and am new to the area. Any help would be much appreciated. Kev.
sparky83 Posted January 15, 2006 Posted January 15, 2006 Do the PIRs still flash when you walk in front in front of them - if they dont you may have blown the auxillary fuse inside the control panel .... Trade Member
Guest kev1 Posted January 15, 2006 Posted January 15, 2006 Do the PIRs still flash when you walk in front in front of them - if they dont you may have blown the auxillary fuse inside the control panel .... No they don't. I'll have a look. The main 'box' has a green light lit up, so I assumed all was ok in there. Probably wrong thing to do!
Guest kev1 Posted January 15, 2006 Posted January 15, 2006 Do the PIRs still flash when you walk in front in front of them - if they dont you may have blown the auxillary fuse inside the control panel .... Checked and sorted!!! Many Thanks. Lesson learned today. I own a garage specialising in BMW's, If you ever need any help, give me a shout!! Thanks again. Kev. Great Forum!
Guest Posted January 15, 2006 Posted January 15, 2006 I own a garage specialising in BMW's, If you ever need any help, give me a shout!!.. have to chance my saab to bmw then..
norman Posted January 15, 2006 Posted January 15, 2006 actually yeah, why dont the indicators work on BMWs I think they did a recall for that... Nothing is foolproof to a sufficiently talented fool.
