Accenta G3 Mini
Guest parkersecurity
Hi All.
I have just bought a house with the Accenta G3 Mini alarm allready installed. I have tried to find out if this alarm can be set up to dial out to say a mobile phone if the alarm goes off :o . Can anyone plese help :) . Thanx in advance.
Guest bandit12gsf
The G3 doesn't come with an autodialer installed, you have to add one. There are terminals inside for various comms devices. It has 6 digital outputs.
ADE do an autodialler called an Informer for about £40 which allows upto three numbers to be programmed plus a "follow me" number which gives you four but the "follow me" has to be put in each time. Wiring these is easy, any questions drop me a line.
I still prefer the Texecom speech and text dialler... it can even send you a text message to tell you when your alarm has gone off.
D
