ian.cant Posted February 22, 2006 Posted February 22, 2006 Yes of course its acceptable but i wouldnt say it was ideal, it may well cause problems but they can be corrected.
Guest bainsy Posted February 26, 2006 Posted February 26, 2006 I use 12/24 volt and lateley i haven't even connected the heaters on the enclosures so that i can run the whole job from 1 transformern and guess what never had a problem with fogging glass as the cameras themselves emit some heat anyway in the box. use rg59 shotgun cable for power and video and cut down the spaghetti.
Guest Posted February 27, 2006 Posted February 27, 2006 I use 12/24 volt and lateley i haven't even connected the heaters on the enclosures so that i can run the whole job from 1 transformern and guess what never had a problem with fogging glass as the cameras themselves emit some heat anyway in the box. ... i duly know the effect of golf stream (eventhou i still use studded wheels) but i would still expect the heaters to be connected..
nikko Posted February 27, 2006 Posted February 27, 2006 All external mains voltage should be on an RCD as its outside the equipotential zone. If the job is for a domestic premises then you cannot do the electrical work unless you are part P registered anyway.I tend to install a Gewis box with RCD in ran from the main dis board. Then have 4A mcb's for each camera. Although Having talked to the likes of Delmiere, VT Genie, most modern day cameras dont always need a heater based housing. Like with the external domes the camera gives enough heat off to keep lense mist free. Only if installed when dry and a pack of silica gel always helps. An RCD doesn't need to be fitted if the Earth Loop Impedance is within the tabulated tolerances. I went up into the attic...I found a Stradavarius & a Picasso. Unfortunately..... Stradavarius couldn't paint, and Picasso made a shocking fiddle. My Facebook page...http://www.facebook.com/home.php#/profile.php?id=1279556853&ref=name
