Gardtec 593 Change The Time ?????
Guest optiop
Hi there,
I have a gardtec with infared remote fob, i only have a fob and i am unaware of any codes at the moment but all i want to do is change the date and time, i can set and unset with the fob and even put in test mode,
please help
If you can put a G593 into test mode, then you have a fob which is programmed as a Master code.
Get to the Test stage, press NO once more -the screen says "Do you want to program Codes" (or "Co_" if you have an LED keypad)
Press NO again, the screen says "Do you want to set Date and Time". Press YES and then your date in 4 digit format (today is 2501), Press YES then the time in 4 digit format (eg 0830) then YES.
You have done it. Press 0 to exit the menu.
Good luck... Come back if you have problems.
With a Master Fob you can add new codes and fobs. Beware dropping them, or changing the battery while programming. You may need a full default reset.
We have ACE fob batteries in stock -
Covering Avon & Somerset, Devon & Cornwall
www.Blanchard Fire & Security.co.uk
NSI Gold
Well, I think that is the first new member I have seen who, in their first post, has tried to sell their services.
Zak Tankel - Managing Director - Security First (UK) - www.securityfirst.uk.com
Disclaimer: Any comments or opinions expressed by me are my own as a member of the public and not of my employer or Company.
You can only change the time and date using a 'MASTER' code. your fob is programmed as a 'MAIN USER' we know this as you can get to rest mode, so even if you buy more fobs you can not program them in.
Contact GardTech support TEL 0 1 6 1 6 5 5 5 6 0 0 and they will advise you on a local company who can help you.
i expect they will come along and service your system, restoring a master code to allow you to administer your system is a very simple matter for an enginner used ti Gardtec Panels, so tops should be about
I'll be putting all Gardtec manuals on my website shortly.
User only I hope!
