regalsafe rs100
Guest Guest
does anyone have a user manual for this panel i have the programming and installer sheets but could really use the user manual thanks
try ther cooper menvier(scantronic) site - their customer literature people sent me a full set of engineering manuals for the regal family otherwise try a local chubb office/engineer they used to fit them in certain areas (where they took a company over).
check the posts elsewhwre on this site i,m sure somebody else was asking about regals
THE BLACK KNIGHT
thanks for your quick reply i will try them
  • 4 weeks later...
Guest andy jinks
didnt know they done a RS100
The RS100 is a large white panel which, to be frank is a nightmare to service. You blow a fuse or knock the power off and you will have to reprogram the panel, and one of the things that makes you realise this is the fact that the SAB sounds until you have programmed it to do otherwise. (I found this out in a little village at 3am, the natives nearly lynched me!!!)
Chubb had a number of these panels as a legacy of the Security Express takeover.
