False Alarm on Aritech Shock Sensor zone
Guest Dan
Hi ,
I would appreciate any tips on what may be causing a false alarm on one particular
zone with 3 Shock sensors (GS613 with reed).
I have an Aritech panel (CS 350) and the same zone keeps reporting a G3 alarm.
I have verified all the wiring , EOL resistor etc, but it keeps happening.
Can Shock sensors be faulty ?
Regards,
Dan
Any Detector can go faulty, have you tried bypassing each one, one at a time so you can determine which one is playing up.
  • 3 months later...
Guest Racer25
Hi
I am try to get a hold of a manual for the CS 350 as we have a very similar problem and until an engineer calls plan on inhibiting the 2 sensors that are faulty.
Thanks
Rob
