Speech Dialer
Guest Ian Lewis
Guest Ian Lewis
Hi all I have a question I hope you can help me with,
I am installing an alarm into my house with a speech dialler and have a question about connecting it,
The alarm is a Lynteck Nexus 8 and the dialler is a Melcom AD1000
The speech dialler has an input witch can be either set to 12v or 0V dc, the panel has 5 connections to the bell box Tamper, TRG, Hold +, Hold
Connect a wire between the TrG terminal on the alarm to the input and program it as negative applied. then follow the instructions as stated.
Thanks everyone for your help,
i have one last thing
The manual said
When input is wired to the bell output negative (-), alarm trigger must be programmed as 0VDC, also a 1K resistor must be wired from bell output negative(-) to bell output positive(+).
Because I am using the trigger not the bell output (-) should I connect the provided resistor from the trigger to the hold + as stated in the book or could this damage my panel ? or is this not required
Thanks again
Ian
TRG is the bell output.
You need to be careful how you wire the bell also, as I suspect you may have the wiring wrong.
