Guest Jason Swain Posted January 27, 2006 Posted January 27, 2006 Hi, I have a sterling 10 alarm panel fitted as per my friend, only the internal sounder on his is quiet and mine is very loud. I can't see anything in the manual to alter the volume level. Any ideas as to how i can reduce the volume on the internal buzzer ? Thanks
FASTCAR Posted January 28, 2006 Posted January 28, 2006 There is a volume pot on the pcb , to the right of the processor.This would involve opening the cover and causing a tamper alarm. ... as ususal..beware of dangerous voltages within..if in doubt , call an engineer. Regards.
Guest Guest Posted January 28, 2006 Posted January 28, 2006 If the tamper alarm goes off .... how do i clear it ? Thanks.
FASTCAR Posted January 28, 2006 Posted January 28, 2006 Just enter your user code...but there is always a slight chance that engineer reset only has been set (is the system monitored ?) if so , an engineers code will be required. Regards,
Mavrick_001 Posted January 28, 2006 Posted January 28, 2006 Normally the tamper reset is programed to any code so it should be fine. On the odd occasion you might find it's on engineer reset which will cause you a problem as you'll need the installer to come back and reset it for you. It's up to you if you want to do it, as long as you know it's a risk it might now reset, 99 times it's not user reset but it's up to you if you want to run the risk. CCTV Intruder Access Control Tony Hughes, Proprietor, TRADE MEMBER
