Guest dunglass Posted January 29, 2006 Posted January 29, 2006 Hope someone will be good enough to help. I am replacing an old corroded bell box with a new siren type with strobe. However, the wiring in the Alarm Panel has the following connections: Strobe +, Strobe -, Bell -, Bell +, T & A The Bell Box has the following connections: +12v, 0v, TAM 0v, NEG Trig, STR Neg If anyone can advise how I should connect the two I would be very grateful.
cdosrun Posted January 29, 2006 Posted January 29, 2006 [Hi, at a guess, I would connect as follows: Bell + - +12v Bell - - 0v Strobe - - STR Neg T - TAM 0v A - NEG Trig anyone else? Andrew Any statement made or information provided in this post are the mere opinions of the author, and no inferrence is to be made as to the quality of information nor should any reliance be placed upon its contents.
bellman Posted January 29, 2006 Posted January 29, 2006 Hope someone will be good enough to help.I am replacing an old corroded bell box with a new siren type with strobe. However, the wiring in the Alarm Panel has the following connections: Strobe +, Strobe -, Bell -, Bell +, T & A The Bell Box has the following connections: +12v, 0v, TAM 0v, NEG Trig, STR Neg If anyone can advise how I should connect the two I would be very grateful. It wires this way. bell + to +12v strobe - to STR neg bell - to NEG trig T to TAM 0v A to 0v You don't need a connection from strobe + to the bell box since it has already got a +ve supply from the bell + Regards Bellman Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
Guest dunglass Posted February 2, 2006 Posted February 2, 2006 It wires this way.bell + to +12v strobe - to STR neg bell - to NEG trig T to TAM 0v A to 0v You don't need a connection from strobe + to the bell box since it has already got a +ve supply from the bell + Regards Bellman Thanks Bellman, I'll get the ladders out at the weekend ! Much appreciated.
Ard Disk Posted February 2, 2006 Posted February 2, 2006 Thanks Bellman, I'll get the ladders out at the weekend !Much appreciated. Weekend!! If you are going to be a proper DIY Alarm Engineer, you ought to fix it within 4 hours of either the wife or Bellman telling you how to do it Covering Avon & Somerset, Devon & Cornwall www.Blanchard Fire & Security.co.uk NSI Gold
bellman Posted February 2, 2006 Posted February 2, 2006 Thanks Bellman, I'll get the ladders out at the weekend !Much appreciated. No worries, always happy to help Weekend!!If you are going to be a proper DIY Alarm Engineer, you ought to fix it within 4 hours of either the wife or Bellman telling you how to do it I'll bow to the higher authority (swmbo) as the penalties are higher Regards Bellman Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
Guest dunglass Posted February 4, 2006 Posted February 4, 2006 Weekend!!If you are going to be a proper DIY Alarm Engineer, you ought to fix it within 4 hours of either the wife or Bellman telling you how to do it Fair point that - I should have asked her first since women are always right. Bellman was of course spot on and it works great (shame about the missus). I'm not trying to over-complicate things, but.... should it be simple to wire in 2 identical bell boxes (one front, one rear) ??
bellman Posted February 4, 2006 Posted February 4, 2006 I see I post the correction of the first post and Chris gets all the thanks??Pete Great minds think alike and all that Pete, and to be fair when I started to write my reply there was only the reply from cdosrun. You must have far nimbler fingers than me Pete Regards Bellman Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
