Concept Madness!!!
Guest PeepsUK
Guest PeepsUK
Iv just moved into a new home with old alarm panel installed, Iv got power to the system and have installed a new battery. Iv also had to replace a few cables and ad sum new detectors. My only problemnow is that i cant program it! Iv checked the the panel and keypad for manufactures names and model numbas but cant find anything but the the word concept on the brown keypad!!!
Could any one pls help me??? If any one has a manual for this panel or infomation on where i can find one, I'd be very gratfull for sum assistance!!!
Many Thanx!!!
Peeps UK!!!
:hmm::no::angry2:
any chance you can post a picture
p
THE BLACK KNIGHT
Guest PeepsUK
Thats the one! Brilliant! Thank You!
Guest PeepsUK
Is it the ADE Optima User Guide?
Guest PeepsUK
Is there any chance any one no's how to do a factory reset or program each zone??
cheers for helping!
I don't think there's much programming you can do on that. Personally I'd rip it out and bin it, especially if you've replaced most of the rest of the system.
We can't give out much in the way of engineering info unfortunately. If you by a new Texecom Veritas then there will be a full manual in there which is very good for DIYers.
Don't forget two zones don't go to end station, there on the rkp....
Beware that when you have printed out the instruction guide, fitted a 3Ah battery (2.1Ah has to be rested one end up on the transformer) and powered it up:
the keypad membrane is probably perished and one or buttons may not work -good luck :)
Covering Avon & Somerset, Devon & Cornwall
www.Blanchard Fire & Security.co.uk
NSI Gold
