Optima Xm6
Guest wfs
Hi
have just moved into a house with a Optima XM6 installed, usual story that the alarm instructions are missing, think I have managed to download them from this site, three pages in total, is that correct?
Just wondering if as the alarm is a few years old is it possible to replace the key pad and also add a couple of Remote key pads to other places in the house.
Any thoughts on this and suggestions as to the best type to use would be appreciated
thanks wfs
I'd get the panel upgraded as the XM can't have RKP's fitted. If you don't, then as a minimum you need your existing system servicing.
If you post your location there may be an installer in your area watching! :ninja:
