shortcircuit Posted January 30, 2006 Posted January 30, 2006 A simple programming operation which I cant get right. Domestic installation with Z2 a PIR on the exit route. I want to isolate this in the part set mode. Programming Set Z2 to be a part set zone " 02 enter 2 Prog" Set Z2 in full set mode "12 enter 6 Prog" To make it an E/E Zone Set Z2 in part set mode "22 enter ??????? Prog" At this point I think I am going wrong. Is there an option to null Z2 in the part set mode Any help much appreciated
PJF Posted January 30, 2006 Posted January 30, 2006 Option code 51, Z2 unlit. Top tip: if you ever catch fire, try to avoid seeing yourself in the mirror, because i bet thats what REALLY throws you into a panic and dont forget the one thing you cant recycle is wasted time.
shortcircuit Posted January 30, 2006 Author Posted January 30, 2006 A simple programming operation which I cant get right.Domestic installation with Z2 a PIR on the exit route. I want to isolate this in the part set mode. Programming Set Z2 to be a part set zone " 02 enter 2 Prog" Set Z2 in full set mode "12 enter 6 Prog" To make it an E/E Zone Set Z2 in part set mode "22 enter ??????? Prog" At this point I think I am going wrong. Is there an option to null Z2 in the part set mode Any help much appreciated I enter "00"
PJF Posted January 30, 2006 Posted January 30, 2006 Ignore my first post. Your right with the 02 option code, the zone light needs to be off. Full set, correct. Now why are you trying to prog a zone type that is going to be omitted. With your first two prog changes it should work fine. Top tip: if you ever catch fire, try to avoid seeing yourself in the mirror, because i bet thats what REALLY throws you into a panic and dont forget the one thing you cant recycle is wasted time.
breff Posted January 30, 2006 Posted January 30, 2006 option 02 then select zone numbers required to be armed in part set (light off=not armed) then press PROG. The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
shortcircuit Posted January 30, 2006 Author Posted January 30, 2006 Ignore my first post. Your right with the 02 option code, the zone light needs to be off.Full set, correct. Now why are you trying to prog a zone type that is going to be omitted. With your first two prog changes it should work fine. It would appear that I am putting the zone light on in "02" as all others were off. It is beging to suggest to me that as others have been before I should default the panel and start again Thanks for your help
PJF Posted January 31, 2006 Posted January 31, 2006 Dont default, just make sure Z2 is off in the part set option, all the rest should be on if they are not included. Top tip: if you ever catch fire, try to avoid seeing yourself in the mirror, because i bet thats what REALLY throws you into a panic and dont forget the one thing you cant recycle is wasted time.
shortcircuit Posted January 31, 2006 Author Posted January 31, 2006 Dont default, just make sure Z2 is off in the part set option, all the rest should be on if they are not included. Thanks for your advise. Did not default Reprogrammed as described and worked perfectly. Its a simple and clever panel to programme once you get your head round it Thanks again
