Guest jmancs Posted February 4, 2006 Posted February 4, 2006 Yes i have: PANEL: ZONE | + | - | BLUE | GREEN | RED | BLACK Then on the P.I.R its: C with 1k resistor to N/C from N/C to T2 with 1k resistor then T1 back to zone but when i do a walk test or chime test, it dont pick me up for any kind of reason and still comes up with 1012 +TAMP S/C Regards, J
Guest jmancs Posted February 4, 2006 Posted February 4, 2006 Okay i shall try again. also The door contacts show same for some reason and all i have is 2 wires going from zone to door contact ? do i need a resistor ? Thanks for helping, much appreciated, James
cdosrun Posted February 4, 2006 Posted February 4, 2006 James, exactly the same rules apply for door contacts when you are using EOL. Just use the diagram as posted above by Alarmgard. You will need resistors just as for the other zones. Andrew Any statement made or information provided in this post are the mere opinions of the author, and no inferrence is to be made as to the quality of information nor should any reliance be placed upon its contents.
Guest jmancs Posted February 4, 2006 Posted February 4, 2006 lads, thanks for ure help, i shall try tommorow and see what happens, i'll keep you posted, James
morph Posted February 4, 2006 Posted February 4, 2006 You have messed the wiring up that is why you are getting the faults, before you started the install did you read the engineers manual?
Guest jmancs Posted February 4, 2006 Posted February 4, 2006 yes over and over again! no idea what its doing!
Guest Posted February 4, 2006 Posted February 4, 2006 what panel is it ? iam assuming galaxy ? if panel type mentioned sorry but did not see it
