Guest Robmanchester Posted February 4, 2006 Share Posted February 4, 2006 Any one every installed any Axis network camera and viewed them remotely? I have a 206 Axis network camera connected to router and then a Motorola blueyounder internet connection. The upload speed is only 256K and makes the update time of the picture slow when viewing remotely (about 1 frame per second). Any one know for any better broadband suppliers with higher upload speeds? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/9215-axis-206-network-camera/ Share on other sites More sharing options...
Rich Posted February 4, 2006 Share Posted February 4, 2006 I think you will find it hard work getting an isp that will give you more than 256k have you thought about saving the images to a pc then uploading from the pc at a different rate? Or changing the camera settings to allow a lower bandwidth? It sounds like you are using highest resolution at 30fps, is that right? So each image if i am right will be 300k(image size) multiply by 30 for one second of information. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/9215-axis-206-network-camera/#findComment-85516 Share on other sites More sharing options...
Guest Posted February 5, 2006 Share Posted February 5, 2006 I think you will find it hard work getting an isp that will give you more than 256k ... that true?? or does the price just go high? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/9215-axis-206-network-camera/#findComment-85643 Share on other sites More sharing options...
Guest Posted February 5, 2006 Share Posted February 5, 2006 that true?? Dunno what the upload is over there Georg but over here 256k is a standard upload speed for all connection speeds. The best way to get better upload speed is to bond multiple DSL connections, but that's pricey. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/9215-axis-206-network-camera/#findComment-85675 Share on other sites More sharing options...
Guest Posted February 5, 2006 Share Posted February 5, 2006 Dunno what the upload is over there Georg but over here 256k is a standard upload speed for all connection speeds. The best way to get better upload speed is to bond multiple DSL connections, but that's pricey. upload rates usually vary from 512k to 1M, download from 512k to 8M (thou there are 24M rates i've heard so, but not seen..) you can still get 256/256 connection, but that will save you Link to comment https://www.thesecurityinstaller.co.uk/community/topic/9215-axis-206-network-camera/#findComment-85690 Share on other sites More sharing options...
robert99d Posted February 5, 2006 Share Posted February 5, 2006 Telewests upload speed is 348k on 4Mb broadband upwards But that Link to comment https://www.thesecurityinstaller.co.uk/community/topic/9215-axis-206-network-camera/#findComment-85704 Share on other sites More sharing options...
Guest Posted February 5, 2006 Share Posted February 5, 2006 Telewests upload speed is 348k on 4Mb broadband upwards But that Link to comment https://www.thesecurityinstaller.co.uk/community/topic/9215-axis-206-network-camera/#findComment-85709 Share on other sites More sharing options...
Guest Posted February 5, 2006 Share Posted February 5, 2006 Ah, that's cable. I was on about DSL connections. me too.. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/9215-axis-206-network-camera/#findComment-85731 Share on other sites More sharing options...
PeterR Posted February 5, 2006 Share Posted February 5, 2006 me too.. Try nildram.co.uk they have SDSL services 1mb and 2mb upload, we have used there 1mb in the past and its great, it is not cheap though and only available in some areas. You can also try Easynet they are a little more expensive but can offer in regions that nildram cannot. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/9215-axis-206-network-camera/#findComment-85754 Share on other sites More sharing options...
amateurandy Posted February 5, 2006 Share Posted February 5, 2006 Try nildram.co.uk they have SDSL services 1mb and 2mb upload, we have used there 1mb in the past and its great, it is not cheap though and only available in some areas.You can also try Easynet they are a little more expensive but can offer in regions that nildram cannot. The main constraint on SDSL (apart from price) is where BT have enabled it. They seem to be moving faster on ADSL+ which can get up to 18Mbps download depending on distance; presumably because they can get more money - e.g. for pay-per-view services. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/9215-axis-206-network-camera/#findComment-85757 Share on other sites More sharing options...
