Long Masonry Drill Bits.
Paul P
I am looking for a replacement supplier for 6mm X 600mm long masonry drill bits.
You know the ones we all use to drill behind the coving. They seam to have become scarce round this way I have even a check to see if screwfix had any.
All suggestion are gratefully received.
Trade Member
As I usually break\bend them I get loads of cheap ones from the Sunday market, think they're only 50p each IIRC (or were last time I got some anyway). I'm down to my last one, could do with some more actually. If you'd have posted this this morning I'd have gone down and got some.
I was stuck once and nipped into a large DIY store and they had ones in there for
gardiners etc usually sell them but you would have to stuck as they are pricey
www.infix.co.uk Brilliant stock and reasonable prices, delivery to all areas - tell them RJB Security Systems sent you.
Tell them their website needs a couple of bits looking at too. ;)
Long screwdriver shaped like a banana. :yes:
+1! Gentle tap with a hammer usually does it, and no risk of nicking any pipes.
Trade Member
Such as?
Such as?
Nothing major, site counter was a bit hit and miss and the search doesn't work.
Looking at the site it's © 2003 so I assume it's not been touched since then.
ahem!!
