Long Masonry Drill Bits.
Paul P
I get mine from the pound shop use 3 times and bin but i get 3 for a quid
Thats 3 at 500mm by 5mm, 8mm and 10mm
i have loads in the garage good value.
I normally use
www.screwfix.com
www.toolstation.com
Very good prices :P
I normally use
www.screwfix.com
www.toolstation.com
Very good prices :P
Any chances of a link to 6mm X 600mm standard masonry bits as I cant find them on either site.
Paul P
Trade Member
Paul P
Dam, just had a look on their website, they don't seem to do it any more.
try
http://www.drillbitdepot.com/images/more_info.gif
what part of the country you in?
best thing to do is put a search into google website. make sure you select uk, enter
long masonry drill bits 6mm x 600mm
see what comes up.
If your based in middx, I know a few good deals
  • 1 month later...
Guest ademco1
I am looking for a replacement supplier for 6mm X 600mm long masonry drill bits.
You know the ones we all use to drill behind the coving. They seam to have become scarce round this way I have even a check to see if screwfix had any.
All suggestion are gratefully received.
You can try Grax Ltd,in Nottingham,manchester and birmingham,very cheap for drilss screws, cctv aerils,satalite etc.
Hilti do them, not cheap, they last well and can be resharpened, worth the investment
*QFA* I also use hilti ones (and resharpen them due to me being a tight northerner), they tend not to jam as much as the cheaper ones as the flutes are slightly different allowing better removal of debris from the hole.
I just wish they wern't as expensive...
Regards
Bellman
Well, none out of 6 aint bad. :P
