Optima Plus 2
Guest Phif25
Hi
Can anybody help, I inadvertantly pushed my panic alarm of the optima puls 2 and set it off. I have managed to switch the alarm off but can't reset the system. Do you know if it is possible to buy a key for the panic alarm to reset it? Also can anyone suggest an engineer who would be able to service the alarm? We are in Dartford Kent.
Thanks
Fiona
I'm sure someone on here will let you know whos in that area, in the mean time if you open the panice button you will be able to reset it, basically have a look where the key goes in and what it pushes up on the other side, once you've opened it you'll see it's not really hard
CCTV Intruder Access Control
Tony Hughes, Proprietor,
TRADE MEMBER
Thanks for that.
Have now got it re set!!
Fiona
