Gardtec 360/580
Guest Guest_Stuart_*
I would be greatful for any help you can give to rectify my alarm system.
I believe it is a 580, although not sure.
I had the system installed a while ago and the installation engineer no longer carries out this type of work.
When the system first went on the blink the LED display was flashing AC 15-44. Now it shows En all the time in the unset mode. When I try to set the alarm the exit sounder sounds, but the system will not set and the LED shows EN again.
If I go into the event log, the only thing that shows in the log is rE. According to the manual this means........... Electronic watchdog reset (engineer message)
I have tried to obtain an Anti-Code or Engineer Code but have been unsuccessful.
Any ideas?
Thank's
Stuart
anti-code reset = definately need an engineer to sort it out for you.
Thank's everyone,
I will get an engineer to take a look at the system
Regard's
Stuart
