Guest r_keates Posted February 11, 2006 Posted February 11, 2006 Hi All, Got 2 questions regarding a new Galaxy 500 i've just installed - it's a hugely excessive panel but the customer wanted a Galaxy and it's what I could lay my hands on at the time. 1. This is the first Galaxy i've installed on my own, and i'm not entirely sure eaxctly how the strobe should be wired at the panel - there are 3 terminals on the board for the strobe, one seems to be a normally open, and then what seems to be a normally closed pair. Currently the strobe is running constantly. How should these terminals be wired so the strobe doesn't flash when the system is "normal"? 2. Prox tags - I remember when the //.National Installer.// guy came and added some tags to our system at work, he showed me how to do it, but it's been such a long time that i'm not sure what he did now. I seem to remember he had to put the tag onto the front of the keypad while he was in a menu. This then brought up a big long number on the display which didn't relate to the number on the tag. He also numbered the tags, because he said that the digits on the panel wouldn't match any numbers on the tags, so if someone lost one we needed to make sure we deleted the correct tag from the system. This only took him about 3 or 4 minutes to do 5 tags. Anyone know this exact procedure, as I really can't remember what to do! Rob
Monteey Posted February 11, 2006 Posted February 11, 2006 I suggest to speak to someone who knows what they're doing as you seem to be out of your depth. Galaxies at the best of times are not easy panels to install and program, and a Galaxy 500 even more so. They are NOT a diy panel therefore unfortunately we cannot help you further. Mark Hawks Ex BT Openreach Field Service Now Self employed telecom and data engineer www.mphtelecom.co.uk Also back doing sub contract work in the security industry. Retained firefighter Devon and Somerset Fire and Rescue
bellman Posted February 11, 2006 Posted February 11, 2006 Adding tags is fairly easy. master code then ent 42 ent display shows 1=user codes press ent then use a and b keys to scroll to the user u wish to add the tag to. press ent to select and display will change to 01=modify pin press 07 and press ent press the b key untill all existing numbers have been deleted then press a + 1 at the same time and keypad will beep, hold prox tag to lower part of keypad and panel will beep and read the number out of the tag. then press ent to store. press 08 then ent to select the card held function press 12 to select timed set then press ent to store press escape 5 times to return to the time date banner. as for the strobe, it has it's own output terminal next to the bell output. run a wire from 0v to the common (middle) terminal of the strobe out, then the wire from the strobe itself into the left hand side terminal of the strobe output. As monteey said above they are not a diy bit of kit and can be a bit tricky at times. Hope this helps Regards Bellman Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
Guest Cyberprog Posted February 15, 2006 Posted February 15, 2006 Adding tags is fairly easy.master code then ent 42 ent display shows 1=user codes press ent then use a and b keys to scroll to the user u wish to add the tag to. press ent to select and display will change to 01=modify pin press 07 and press ent press the b key untill all existing numbers have been deleted then press a + 1 at the same time and keypad will beep, hold prox tag to lower part of keypad and panel will beep and read the number out of the tag. then press ent to store. press 08 then ent to select the card held function press 12 to select timed set then press ent to store press escape 5 times to return to the time date banner. as for the strobe, it has it's own output terminal next to the bell output. run a wire from 0v to the common (middle) terminal of the strobe out, then the wire from the strobe itself into the left hand side terminal of the strobe output. As monteey said above they are not a diy bit of kit and can be a bit tricky at times. Hope this helps Regards Bellman And presumably the strobe output would need to be 0V normal, 12V in alarm condition, sometimes they're set the opposite way round, and need switching arround through the software.
bellman Posted February 15, 2006 Posted February 15, 2006 And presumably the strobe output would need to be 0V normal, 12V in alarm condition, sometimes they're set the opposite way round, and need switching arround through the software. No, It's a relay, Hence wire from 0v to the middle (common) terminal and strobe switched -ve to the right (n/o) terminal. Regards Bellman Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
norman Posted February 15, 2006 Posted February 15, 2006 That would be a voltage free relay. Nothing is foolproof to a sufficiently talented fool.
Nova-Security Posted February 15, 2006 Posted February 15, 2006 And presumably the strobe output would need to be 0V normal, 12V in alarm condition, sometimes they're set the opposite way round, and need switching arround through the software. Strobe needs -ve to work. www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
whistle Posted February 15, 2006 Posted February 15, 2006 That depends if its an old ctype box and the stobe has a perm neg you could switch the pos.
