Advice Dvr With Remote Access And Passthru's
Guest Staplar
Thanks for your reply, I had a look for a Philex RF Modulator, it looks like it only takes a single input, is there such a device that has 4 BNC inputs to 1 BNC output?
Yes, but it's cheaper to buy 4 single channel modulators as the multichannel ones are generally for broadcast quality high end sytems from what I've seen.
I suppose you could use a 4 way switcher prior to the modulator, which would be cheaper that 4 modulators, after all you can only look at one picture at a time, unless your planning on 4 TV's.
Guest Staplar
I was under the impression that I would not need a modulator, the loftbox does that (I think). There is a BNC input on the Loftbox labelled CCTV. I am not too bothered about cycling through each camera, I was looking for solution that would display multiple cameras on one screen, which I could see on my TV via the loftbox (Labgear HDU681).
Thanks for you reply.
Right, I think that "high end" kit is probably too expensive. Thanks for your reply.
The F type input on the loftbox is an rf input, you will need an rf modulator.
So like i said. fit a 4 way switcher prior to the Modulator you could then view any of the 4 camera's at anytime and have them sequence also.
Alternativly you may be able to get a quad or a mux and do it that way but why have 4 little pictures when you could select any of the 4 singularly? provided you site the switcher in a usable position.
System Q do a 4 camera controller that can go in the attic with a built in modulator & 12 volts for the cameras, it can be set to switch cameras sequentially or when triggered by sensors or controlled by a wireless keyfob from anywhere in the house.
But if you have 4 modulators you have the means to select any camera at full screen from any TV. 4 modulators would cost about the same as or less than a semi decent switcher\quad\mux.
