Guest pumbaa Posted February 15, 2006 Posted February 15, 2006 Hi All, I''ve just had a quote for a sytem and have requested a change. The original system had a Veritas R 8 Plus Control Box and i've now asked for a LCD Excel key pad so that's an upgrade from the Veritas R 8 Plus to the Veritas Excel. Now the installer has indicated this upgrade will be
Allso Posted February 15, 2006 Posted February 15, 2006 If you search on the internet you can get an idea of the prices of the different keypads. I can't list them here because of forum rules. I think you already suspect the correct answer to your question! Allso
FASTCAR Posted February 15, 2006 Posted February 15, 2006 There are a few different flavours ..standard LCD , larger LCD , prox , flush ..or, if you go for the flush satin finish you could end up paying more than
Guest pumbaa Posted February 15, 2006 Posted February 15, 2006 Yeh, i've managed to get a few prices for the same kit. I've asked them to explain the cost as well as to confirm the grade of the proposed system and if they install to any of the recognised standards. They seems to be a general electronics company plug sockets, lights, satallites etc who do alarms as well. I might have to keep looking. There are a few different flavours ..standard LCD , larger LCD , prox , flush ..or, if you go for the flush satin finish you could end up paying more than
Monteey Posted February 15, 2006 Posted February 15, 2006 There are a few different flavours ..standard LCD , larger LCD , prox , flush ..or, if you go for the flush satin finish you could end up paying more than Mark Hawks Ex BT Openreach Field Service Now Self employed telecom and data engineer www.mphtelecom.co.uk Also back doing sub contract work in the security industry. Retained firefighter Devon and Somerset Fire and Rescue
Guest Posted February 15, 2006 Posted February 15, 2006 ...I can't list them here because of forum rules. ... Allso trade prices are prohibited as far as i remember..
breff Posted February 15, 2006 Posted February 15, 2006 edited as didnt read previous posts properly The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
morph Posted February 15, 2006 Posted February 15, 2006 Is this a new install and the Excell kepad is being fitted at the same time? if it is remember that even although its only a change, its simply not sold at cost.
Guest pumbaa Posted February 15, 2006 Posted February 15, 2006 trade prices are prohibited as far as i remember..
morph Posted February 15, 2006 Posted February 15, 2006 Now are you being serious or not?Remember the cost of the original panel and keypad are in the quote already. Seeing as i've found the veritas excel Panel and Keypad for less than
