Anyone know what's happened to A1 Alarms ?
Guest Superwidget
Guest Superwidget
Hi all
Does anyone know what has happened to A1 Alarms ? :o
Are there still in business ?? :!:
If so does anyone know the address of their web page ??? :blink:
If there are 'gone' does anyone know if the AJ600 is still being sold by a different manufacture ? :wacko:
Thanks
Superwidget
Guest oldtimer
I hace no idea what happened to A1 but would point out that these panels were sold as kits from B&Q.
It is actually an Omnicron panel and was also badged as a Tec Diamond.
Apart from that do you have a problem wiyh this panel.
Guest oldtimer
A1 Security Electronics ltd
16bricksfields Huyton
Merseyside
L36 6HY
0151-489-0166
Hope this helps
I thought they were taken over by Micromark?
  • 4 weeks later...
Guest granleyss
A1 alarms went into receivership and the business was split into two one half was took over by responses alarms (the diy solar alarm manufactor) and the other by ADE hope this helps
Guest oldtimer
The AJ600 or the Omnicron Tec Diamond was sold via B&Q and City Electrical.
A1 are no longer trading and s for the panel it was aimed at the DIY /Electrical contractor market. The only bother I had with it was that if it got a voltage spike
it activated a full alarm and locked out the key pad. The only way to reset it was to power it down to return it to factory settings as it did not have a NVM chip.
Guest Peter James
Why look a gift horse in the mouth and just be grateful they're gone! :)
