Optima Xl6
Guest sboothd
Guest sboothd
I have an idea what the code is but do not want to try it in case I am wrong. If i enter the wrong code, will the alarm go off????
No, the alarm will only accept the last 4 numbers entered, if it is wrong nothing will happen. However, if you contiune to keep entering codes in an effort to guess the code it will go off in tamper, my suggestion is 2 codes and stop, if that doesn't work it's time for an engineer
CCTV Intruder Access Control
Tony Hughes, Proprietor,
TRADE MEMBER
