Guest louise0171 Posted February 17, 2006 Posted February 17, 2006 On a pre 2000 veritas 8 does anyone know how to make zone 1, the door, the exit entry zone. thanx.
Guest Posted February 17, 2006 Posted February 17, 2006 eng code then prog 1,1, 6, prog, you should get double beep (full set zone type) from eng menu 2,1,6,prog you should get double beep (part set zone type) then press reset to put back to day. this assuming you've got the eng. code (maybe its one of arfur's job's )
