Veritas 8c
Guest 1966england
Guest 1966england
Hi,
When I PART set the alarm and then enter the alarmed area the external bell box does not ring. When the alarm is set to FULL and I enter the alarmed area the external bell box rings as expected.
Does anyone know how to rectify this situation.
Regards.
Hi,
the programming option you want is probably Miscellaneous 01, Option 2. The factory default is to on, if you switch it off, the siren should sound in part set.
Andrew
Any statement made or information provided in this post are the mere opinions of the author, and no inferrence is to be made as to the quality of information nor should any reliance be placed upon its contents.
