Ademco 4110uxm - How To Disable The Comms?
Guest spirochete
I was using these with point ID years ago to an Ademco receiver, then moved 'forward' to 3 pins on a RedCare!!!!
At what price progress :no:
Guest spirochete
Just as a follow-up guys,(not quite on the original thread topic but part and parcel of the same project)........
What, in your experience is the best /better type of sensor to use on 'up and over' garage doors?
The usual surface magnetics are an obvious possibility, but maybe there is something just that bit better out there?
(Thinking in terms of robustness/tamper resistance).
Spiro'
There are plenty of industrial type contacts on the market. Usually housed in Aluminium and sealed with silicone.
Guest spirochete
Thanks 'SE',
The Aluminium floor plates look an interesting possibility, I might well go for those.
Spiro'
  • 1 month later...
Guest alarm freak
i would strongly disagree with the fact its a superb panel to, the panel has a very short bell test 3 seconds i think hardly enough time to run outside to check if all is well :realmad:
There's other ways to check it apart from the inbuilt test :yes:
Regards
Bellman
