Honeywell G2-12
C.S TEK.
Am i missing something or do i have a faulty panel???
Programed G2-12 last week and set landing detector for day mode 03 Intruder, part mode and Night mode 00 not Active. Come out of programming, night set it and it goes of on landing DT, look in programming and to find it has gone back to 03 intruder on part and night setting. tryed it again a few times and it still done the same, Have i not turned something on or does it have to be programmed somerthing else at night. There aint no options for zone now is there???
cheers All
Chris
Trade Member
Use # to toggle the zone types for part/night.
Aye, choose your time for full set then press # to go onto part and nightset, not Ent. :yes:
Had another g2-12 today.Messed around and found that the # keys helps. Thanx all.
Also noticed that you gotta change options in dd243 menu to allow user to disarm night/part set if using a code.
chris
Trade Member
