borris Posted December 2, 2003 Posted December 2, 2003 Hi all I would be greatful if anyone has any info on the above panel. .
Guest oldtimer Posted December 3, 2003 Posted December 3, 2003 Well this is an old chesnut. The Bentley F 133 is a 4 zone alarm panel exit/entry zone and zones 1,2&3 (cream & orange in colour) (Bentley were also one of the first manufacturers to fit a NVM chip & a mains filter) The panel you have is about 15-20 years old so me thinks you should replace it. Yes I do have a manuaul but as you are aware the rules of the forum is that this info is not for general distribution.
morph Posted December 3, 2003 Posted December 3, 2003 If you are only using it as a bells only system then you dont need to change it simply because it is old. Bentley are still making them and supporting them with spares and manuals etc. Colin.
JB_ Posted December 3, 2003 Posted December 3, 2003 Good sturdy panel bentley's are, very rarely do we replace one due to a failure, most of the time it's due to an upgrade.
Service Engineer Posted December 3, 2003 Posted December 3, 2003 The old Bently 133 and Symphony are two panels im quite fond of, my old employer had fitted hundreds of these before i started and he swore by them. Ive only ever replaced one because it was faulty, any others ive replaced have been due to upgrading. The build quality of these Bentleys was great, its no wonder they seem to last forever. ........................................................ Dave Partridge (Romec Service Engineer)
Guest andy jinks Posted December 3, 2003 Posted December 3, 2003 a common fault with the symphonys and f133 was the key pads getting worn out .. Ive seen them so bad that if you thump the wall they enter codes,so check it for stretching of the membrain and change the code tryin not to use the same numbers.
morph Posted December 4, 2003 Posted December 4, 2003 You can get new a membrain for them for a bout a tenner. Colin.
Guest HomeSecurityServicesUK Posted December 21, 2003 Posted December 21, 2003 now theres a blast from the past
p.jones3 Posted September 25, 2005 Posted September 25, 2005 i need a manual for the bentley f133 for a friend that needs help with it
morph Posted September 25, 2005 Posted September 25, 2005 The site does not give out engineering manuals unless you are in the trade and can prove it. Apply for trade membership if you are trade and there is a manual in the engineering manuals section.
