Guest frosted Posted February 26, 2006 Posted February 26, 2006 bangheadif you spread your credit card PIN number around just like your transmission medium is spreading the traffic all around if you don't use directional antennas. then only encryption key ( ie. your credit card number ) is needed anymore. yes but the only issue if the wirelsss network is sucure is someone comming along with a device to mess the transmission up. which they can do with directinol as well. still not following .....
Guest Posted February 26, 2006 Posted February 26, 2006 yes but the only issue if the wirelsss network is sucure is someone comming along with a device to mess the transmission up. which they can do with directinol as well.still not following ..... it much harder to "mess up" the traffic when using directional antennas. still not following ..... don't worry.. i am not able to explain now well enough because i am a bit pee'd off due to lose in icehockey game.. i am more concerned about to drink or to drink a lot..
Guest frosted Posted February 27, 2006 Posted February 27, 2006 it much harder to "mess up" the traffic when using directional antennas.don't worry.. i am not able to explain now well enough because i am a bit pee'd off due to lose in icehockey game.. i am more concerned about to drink or to drink a lot.. you cant mess up traffic using a normal wirelss system. its viewed as a seperate network for one. sigh. maybe it over your end it a differnt world to the uk lol. and using hardware keys the only way to get in is from the internal network.
