New Remote Pad Required For Paragon Plus ?
Guest steveho
Guest steveho
MPMP you mekons
Right then from your advice/slating i must replace the battery before my house burns down and get out my portasol and solder the dry joint on the transistor
regarding your opinions on pyronix systems all i can say is from experience with my system it does the job it was designed to do with the utmost reliabilty -i can't ask anything more than that
thanks for all your replies - eventually
  • 2 weeks later...
battery fitted for
Guest steveho
Hi steve, the chip with 3 pins is probably a regulator or some form of oscillator, I suspect a dry joint from what you have said, it WILL need resoldering to provide a good repair, the temp fix you have done although functional isn't right and needs correction.
There is a DIY service guide on the main site that may prove usefull to you.
Regards
Bellman
Thanks bellman,
that's good advice -i will drop a bit of solder on that joint to sort it permanantly and just check my new battery is getting a good charge
  • 5 months later...
[quote
Now Galaxy 3, Aplex, Aritech ATS and cracking kit, I would have to agree but not that cack the keypads never worked 100% anyway.
Update,not touched it since and behaving pefectly-6 months later :yes:
>MOD>No need for remarks thx.
If aforementioned equipment is ok now, then I will close this topic<
